Present in 3.1.6 and 3.1.7.1.b
Error:
Last FFmpeg messages:
Malformed AAC bitstream detected: use the audio bitstream filter ‘aac_adtstoasc’ to fix it (‘-bsf:a aac_adtstoasc’ option with ffmpeg)
av_interleaved_write_frame(): Operation not permitted
Error muxing a packet for output file #0
no ICC profile found, will write nclx/nclc colour info instead
Error writing trailer of E:/test-clip-02_prob3_temp.mov: Operation not permitted
frame= 2 fps=0.4 q=-0.0 Lsize= 0kB time=00:00:01.19 bitrate= 0.0kbits/s dup=2 drop=0 speed=0.236x
video source:
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Format settings, GOP : M=1, N=15
Codec ID : 27
Duration : 29 s 983 ms
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio source:
Menu ID : 1 (0x1)
Format : AVC / AAC
Duration : 29 s 933 ms
List : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name : Service01
Service provider : FFmpeg
Service type : digital television
