Just installed 3.3.10. Ram bug is still present.
Just tried it. Worked fine for default uprez from hd to 4k. When I tried iris and added motion blur and stabilization I got the beachball of death after around 15 minutes and my iMac rebooted
Yes, as it seems with all 3.3.x versions.
In the 3.4.x.x alpha this RAM bug is solved - so you might want to try these.
It looks like the wrong link was shared, I have corrected it! You will want to be on the v3.4.0.1 alpha
Wrong build was posted, apologies!
The new alpha link here above ? That does not work, page private or not existing.
Is this the only link here to the Alpha, or do I have to look somewhere else ?
Would like to try it
thx
is there a link for the 3.4.x.x. alpha?
@dwiener @tobias
I guess you have to apply for being Beta tester to be able to visit that thread / download the alpha version.
Other that that this is the correct link:
https://community.topazlabs.com/t/topaz-video-ai-alpha-v3-4-0-1-a/49436
This link is only viewable if you are a beta tester, if you are not, I can share the direct link with you.
Could you post the correct one?
Got invited to the Beta (Alpha) booth, thank you.
Alpha 3.4.0.1.a runs fine on my M2 Macs. The video which caused problem with previous builds now runs.
No memory problems. 720x576 upscaled to HD or 4K with Iris and square pixels is no issue any more.
Upscaling to HD is less Ram intensive and fast (less than 6h for that movie). 4k is much slower (3 days) and needs more Ram. But so far all good and stable.
Thx Topaz Team, your are working fast and really care ! Got some tiny issues with the GUI and others things, but its working again. Will test more on my M2/M1 with different settings.
Could you share the direct link. I am not a beta tester
I will DM you ![]()
