The same video file. However, I am now back at version 3.2.2. My guess is that it is due to the dual GPU configuration. I have 2x 3080 Ti. Maybe in 3.2.3. only one GPU is used in general.
For me it was kinda false alarm.
It appears that my default preset has been altered (by itself) and the ususal Artemis filter had been replaced by Proteus.
After recreating the preset with Artemis, speed is back to the ususal 27 fps.
It’s kinda weird behaviour. After loading a preset, any change to the filter chain causes the text “Modified” to appear behind the preset name.
But this “modified” stays indefinitely – even if I load the preset anew after an app restart.
So it appears that presets are getting overwritten without explicit instruction to do so.
It doesn’t work as described.
The (Modified) suffix is always shown, even after I “apply” my preset.
And “applying” shouldn’t be necessary at all, if the app just had a fresh start. With the only actions performed were 1) adding a video file and subsequently 2) selecting a preset.
No options in the filter chain were changed manually.
