[Please describe your issue
here. Try to include logs (Help → Logging) and add screenshots if necessary.]
- Open image
- Stop regular enhancements
- Start the ‘Remove Tool’
- Click on ‘Object Selction’
- try to use…
BOOM program disappears. It exits, and nothing goes in the Windows Event Viewer.
Topaz Labs | Support Page
