Like I have a RTX 5090 and 9800X3D but this thing still runs like the washing machine from 19th century:
A. Starlight mini of course keeps loading model
…with 100% CPU and 89% GPU (Yes Yes I know there is already another post about it with a solution but hey, what if I want my 5090 achieve its full capacity?)
B. GPU only runs at 40% (CPU FULL RUNNING) and keeps jumping from 1 to 40%, as a result, real low speed
…OK fine, I’ll go with other regular models but still (like c’om):
8 hours? 6fps? OMG did I get a fake 5090??? TRUST ME I did choose the right “AI processor” and tried BOTH gaming and studio drivers DxDiag.txt (145.3 KB) logsForSupport.zip (3.9 MB)
THIS IS THE PROBLEM: like even GPU-Z can not believe that on a GPU-AI software, my 5090 is only running a 40% overall and the 9800X3D is doing all the job:
I knew Topaz Video AI from way back like 5 years ago (yeah it was called enhance or something) and now I wanted to come back for its new features. It now runs much less on GPU than before, or did the trend shift to CPU now?
Real slow processing speed like 0.1 fps…Gosh I wish other 5090s did the same
During this, CPU seems stable, but GPU has straight 0-100% intervals (see the screenshot above)
B. The unbelievably slow performance… remains under both types of drivers:
One side observation yesterday and today for this kind of non-startlight processing: in the first 10 seconds, the performance would be like 40fps+ and then quickly dropping to 5-6fps as seen above
I am also using a 5090 and experiencing the same performance issues with Starlight Mini. 2 - 3 hours to process a 20 sec clip Is this just to force us to use the Starlight Cloud?
you do SLm @4k and 120fps frame interpolation? For sure then it’s super slow and CPU goes to 100%. I your Screenshot Memory usage is near max, I think you need 64GB Ram doing this. About frame interpolation, I recommend doing afterswards with the SLm upscaled one.
I think there is still lots of room for 21gb on my 32gb ram. Plus, if the software’s full potential can not be achieved by this C-GPU combination, I do not know what one could upgrade for it on the current consumer market.
