Yes on one, no on two
You wanted feedback on Photo AI 2.0.
I do like the new V2 Sharpen, because it’s not as sensitive to the strength setting as some of the other ones (like Lens Blur) but it’s also very obvious when you overdo it.
I don’t like the Beta Lighting Adjust. I had a photo where the highlights were blown out and figured I’d try fixing it in post-post, but when I turned on this option, it just over-brightened the whole image.
Can you upload the image so I can run some tests on my end?
Hi, I took a closer look at it and it didn’t really screw up the highlights or the image, but it boosted shadow detail a bit more than it should have (in my opinion, anyway)
P.S. This is the image before Topaz Photo AI.
