I know what happened had to be my doing but I want to be sure.
I was working on the Kimball print that was posted on Facebook and had done some manipulations and had used Textures right before I went into Impressions. The texture I had selected disappeared when I went into Impressions.
Is that normal?
PC. Win 10 user.
Help!
Yes, it’s normal. Before using Impession, you must save it using the Apply button, if you use Impression from the left menu and not from the Adjustments menu.
To take it a step further, any time you have adjustments on the right side, you must click “Apply” before you add an effect from the left side.
Effects from the left side will always replace whatever adjustments are sitting on the right.
