I am wondering when is the best time to sharpen the images, either in TIFF after re-sizing or after being saved to JPEG.
I am fairly new to DeNoise & Sharpen. I shoot NEF, my workflow nowadays is to bring the pictures in Lightroom do some basic adjustments, export to TIFF, run them through DeNoise and save them as TIFF. After that I bring them into Photoshop, finish them up, either crop of re-size then save as JPEG.
I read conflicting information, some say save as TIFF after re-working and re-sizing, run them through Sharpen, and save them as JPEG from Sharpen, other sites say save them as JPEG then run them through Sharpen.
I will greatly appreciate your feedback, I am enjoying working with both products and would like to get the best result out of them.
Sharpen should be applied as the last step to clean up the image and get it ready for export. If you use Lightroom you can export the TIF/TIFF, sharpen and return to LR where you can export to JPG without any Lightroom sharpening applied.
If you use Sharpen, run the TIF/TIFF through Sharpen and then Save as JPG. The reason for this is that the TIF/TIFF is lossless and you have less chance of getting artifacts in the JPG output.
Right, sometimes it might make sense to do it earlier in the workflow especially to see if it’s able to be saved from focus or stability issues and worth working on. It should be run again one last time as a final step to sharpen. Which I’m assuming is separate from output sharpening.
I’m using Topaz Photo AI
I’m wondering if I have to (re)sharpen a little on LR export when I downsize my RAWs to 2048px wide.
Here are my steps on a 45mpx raw NEF file:
Apply Lr medium sharpen preset (amount 45) to recover some lost sharpening in the Raw file
Do all the post-processing
In the end send the image to Topaz Photo AI (via Plug-in extras…)
Apply autopilot settings or tweak sharpening if not obvious enough
comes back as DNG
Export as JPG, resize to 2048px wide, and at this point i’d like to know if applying some export sharpening (screen) is needed to recover/recover some of the Topaz AI sharpening that might be lost in the downsizing process.
