Hopefully I can get the screen shots to upload losslessly on here.
My goal is to output any video I have to FHD to be able to stream to my TV with Plex through a new Roku player. All DVDs get upscaled, and some Blu-rays get denoised. I finally found the right CRF value for libx265 to keep all the details I care about, but if I use TVAI at all, I’m getting something I don’t want.
This is a sample of what I have been saving all my videos in: yuv420p.
I keep noticing the fairly well defined lines in the color gradients. I suspect this is from the colorspace conversion that has to happen to get from rgb48le to yuv420p. I output TVAI to tiff to keep a pure output, then I use ffmpeg zscale to convert it to yuv420p with -vf "zscale=pin=bt709:min=gbr:tin=bt709:rin=pc:d=3:p=709:t=709:m=709:r=tv:c=input,format=yuv420p. This displays the colors correctly on my setup, but in dark parts, it’s got those gradient lines.
Now, if I change the pixel format to a higher bit depth, the gradient lines go away, but getting the files to play on my setup is spotty.
I got this result with the commad -vf "zscale=pin=bt709:min=gbr:tin=bt709:rin=pc:d=3:p=709:t=709:m=709:r=tv:c=input,format=yuv422p10le and I set the H.265 profile to main422-10 instead of main.
What am I missing? What can I do to not get the gradient lines, but still have the output in yuv420p?
Or, if that’s not possible, what can I do to get my Roku player to be able to play every main422-10 H.265 file?
