Weft pattern
Hi everyone!
I try to swith the frame rate from 25fps to 50fps for a 4k 3D animation, and I have some issues with some area where are small patterns.
I tried Chronos and Apollo model (with regular parameters) but the same artefacts occurs on the generated frames.
This produce a huge flickering.
Does someone find a solution for this problem?
Thanks!
That looks to be a tough pattern for the AI models to handle when adjusting for the frame rate change. Have you tried running Aion on this clip?
Thank might have a better result but it is still going to be tough with that detail and fine lines.
Hi Kyle,
thank you for your answer. I just tried with the Aion model, it’s slightly better but the same kind of artifact still occurs.
If in a future release a model could handle these kind of pattern, that would be heavily appreciate: :slight_smile: because trames and patterns are common in archviz visualization.
Thanks again for your reply.
Definitely, if you want to make a post on the Ideas section and include those screenshots it will be helpful to illustrate the issue and what the research team needs to look into.
