After processing is complete with Starlight Mini, the VRAM and sometimes the GPU usage remains totally consumed. This makes is so that attempting another export afterwards with any model will cause the whole system to struggle. Quitting often causes the program to hang, so the only remedy is to kill the process.
What are your specs? OS, TVAI version, GPU driver version?
Can you send the logs to the support team so we can investigate further? help@topazlabs.com
Forget 591.74 with Ada Lovelace
Roll back to 537.58
I have faced the same issue countless times. Killing runner.exe from Task Manager frees the VRAM.
Why?
Most apps are not compatible with drivers that old.
537.58 worked. 55x/59x drivers regressed CUDA/DXGI interop, exposing Windows’ display-GPU lock and breaking TVAI multi-GPU pipelines.
This is known situation reported either on reddit by users or developper on the other hand.
I’m not rolling back for such a specific issue
Also, switching to the studio driver fixed it, I think
