I also have the same issue!
I know the reason why it crashed. When I ran PR rendering videos at the same time, even a 3 min short clip, 1.2.1 would crash for sure.
thatās right, when VE is working donāt use any other gpu demanding application or game or VE crashes.
OK, got it, hope that will work for me. Tks~
Can Gaia CG mod apply to no-CG videos such as interview clips?
Yes !
yes of course and the results are great too!
Yes, thatās the best result i have for most of my videos, CGi or Not, so i use it all the time
Great news! Iāll give it a shot tonight, tks!
Cool, great to hear that! Iāll try CG mode after work,tks~!
Tks ~ļ¼Iāll try it as soon as possible!
letās hope they can release 1.2.6 soon then
Is there a download archive? this latest version is a step backwards for me. I miss the MQ
The LQ sometimes treats cloth textures as noise and smooths it out, where the MQ did a better job in some cases. I have uninstalled the latest version and am trying to find where I put the previous version installer, but I must have deleted it. A link to the previous version would me helpful, thanks
Wow 0.53sec/frame, 2080ti ?
Nope; Iām running an RTX 2070 XC Ultra Gaming from EVGA. Its a beast, for sure!
Just installed it for the first time, on Mojave 10.14.6, and it crashes on launch:
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x3] Wrong version
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/libgobject-2.0.0.dylib
Referenced from: /Applications/Topaz Labs/Topaz Video Enhance AI/Topaz Video Enhance AI.app/Contents/Frameworks/libopencv_videoio.4.2.0.dylib
Reason: Incompatible library version: libopencv_videoio.4.2.dylib requires version 6201.0.0 or later, but libgobject-2.0.0.dylib provides version 5801.0.0
Gigapixel AI runs fine.
they did provide some users with a 1.1.0 download link if you use the search engine youāll find it. So far thatās the only link they provided in the forums, and thereās at least one user who got a ā1.2.6 betaā link but it was on private I guess.
OK, thanks for the info
Id like to see them use the NVENC encoder if possible. if that takes away from the performance because the GPU is too busy, then a CPU based encoder if fine tooā¦ what ever it takes to speed it it with great results.
It wonāt load on for me, I get AI Engine Failure - Iām trying to use CPU mode as my graphics card (Tesla C2075) is too old. Looking at the logs, it looks like it fails when trying to allocate memory. I have 180GB of memory, so size is not an issue.
Some people mentioned this might be a problem with 1.2.1 version, and that 1.1 version does not have this bug. Could someone post a 1.1 version? I canāt find any download links for the 1.1 version.
