I have an old wedding video that was shot around 2001 on a consumer SD video camera.
I did a full capture of the tape a while ago and it’s 720 × 480 resolution, DV/DVCPRO - NTSC format and it’s interlaced footage.
Based on some stuff I’ve read around I used Apple Compressor to export the video at 50 fps progressive with ProRes 422 HQ at 3840x2160 before feeding it to Enhance AI.
I’ve gone through and tried all the different options and candidly I am not getting results that are that much improved.
There’s no way to attach videos here but I uploaded a clip to Imgur as an pre-example. This is post progressive output as mentioned above.
Any suggestions and ideas would be greatly appreciated!
Not having a lot of luck with this— I’ve exported a progressive version of the video at a smaller size as you suggested but it hasn’t helped VideoEnhance make it much better – I’ve all the various options.
Thanks, I just updated to the new version that does interlaced video and WOW! It’s pretty amazing. I just did a couple of tests and it looks amazing. I’m doing about 6000 frames to see what it can do but so far, it’s fantastic looking.
