I had a short demo period of Video AI which went fine. I bought the full version, 6.0.1, Windows. Now in the AE Effects>Topaz dropdown “Enhance” is not listed, only “Frame Interpolation”. I uninstalled and reinstalled Video AI, it still does not work. I need the plugin to work in both AE 2024 and 2025. I need help please!
Try these steps to have it enabled.
Manual Adobe After Effects Enable Option
Sometimes After Effects may have disabled the plugins from working even though they may have been installed.
Please follow the following steps to ensure that the plugins are enabled, but additionally that they are being recognized by After Effects.
First open the Creative Cloud app.
Hold down the Ctrl + Alt + Shift keys (or Command + Option + Shift keys on a Mac), click to open Adobe After Effects.
This will open up a menu. After Effects will present you with an option to “Delete Preferences” and allow you to “Manage Plug-Ins”. Please note that this menu was under the creative cloud page, so if you don’t see it, that’s why. Click the “Manage Plug-Ins” button.
- This opens Adobe After Effects and the Effect Manager menu will appear. Here, you should find the Topaz plugins. My image includes BETA versions, but you should just see Enhance and Frame Interpolation. Here you can enable them if they were disabled. Be sure to hit Okay to save.
Perfect. This was the solution, and I appreciate the help!
And what if it doesn’t show up in Manage Plugins?
