Hi there
I may be doing something wrong but VEAI is forgetting the setting I am trying to use for multiple videos? What I mean by this is I want to use the exact same setting for more than one video and VEAI used to allow me to do so by some means. I have tried various methods in order to get the same setting in each video but it doesn’t seem to work?
I may have forgot the exact method to do so?
Open multiple videos at the same time for processing instead of only one at a time.
I’ve been doing that but it doesn’t work?
Did you select Edit All? … And, what happens?
When I select Edit All then look at the settings for the other videos it just gives me the default settings instead of the one I created. I then have to go through them individually for each setting?
