I want to be able to have 2 processes per clip.
- Interlace AI conversion at the same scale as the original.
- Then upscale this clip using a progressive AI.
Can this be something that can be automated as a custom setting?
Why two steps?
Iris does this in high quality in one step…
Unfortunately from my tests it doesn’t give exactly what I want, but this way does. I might look into a doing a bash script via the terminal.
I would recommend two passes, model chaining with progressive and interlaced models is not yet supported. Although, you can chain these enhancements using terminal.
Plus as always the final result is amazing… very impressive.
