We have had so many great posts since the forum restart that it is sometimes difficult to find them when you want to try something you have seen. Here is an easy a way to get back to your favorites. It uses the forum’s bookmarking functionality.
When you see a thread with an image or technique you want to come back to use the "Bookmark " button at the bottom of thread. This flags the thread for you for future reference.
To find your Bookmarks select the search icon in the upper right corner. Now click Options.
There is a drop down under “Only return topics/posts that …” Select “I’ve bookmarked” and search.
You will now see a list of all the posts you have bookmarked. You can remove bookmarks at any time simply by clicking the bookmark icon.
