Using qsv or vaapi under Linux
Hi together,
was trying to use the actual beta (3.5.3.0.b) under ubuntu on an hetzner dedicated root server.
It hasnt a nvidia card but only the quick-sync part of the cpu.
I was trying to use ffmpeg with the qsv or vaapi specific options but it looks like the ffmpeg-version isnt compiled with support for them.
Would it be possible to compile it by myself to test it with qsv or vaapi?
Has anyone done something like that?
Many thanks
