Upscale and Gaia Performance Test request for 4090 owners
here you go :slight_smile:
Topaz Video AI  v3.2.3
System Information
OS: Windows v11.2009
CPU: 13th Gen Intel(R) Core(TM) i9-13900K  63.715 GB
GPU: NVIDIA GeForce RTX 4090  23.59 GB
Processing Settings: device: 0 vram: 1 instances: 1
Input Resolution: 1920x1080
Benchmark Results
Artemis		1X: 37.39 fps 	2X: 21.76 fps 	4X: 6.00 fps
Proteus		1X: 33.37 fps 	2X: 19.47 fps 	4X: 6.47 fps
Gaia		1X: 15.34 fps 	2X: 10.57 fps 	4X: 6.53 fps
4X Slowmo		Apollo: 43.41 fps 	APFast: 73.53 fps 	Chronos: 30.43 fps 	CHFast: 34.88 fps
Good numbers!
@hugedownload
Do you mind sharing more about your configuration / clocks? I would like to see if/how I can increase my speed at least a little even though only my CPU has an AIO.
I just upped my 4090’s wattage to 600w tonight and am getting a more solid 8.9 with fewer drops.
I do not believe that I have otherwise overclocked it yet.
I haven’t overclocked my CPU and have kept multi-core enhancement off / power limit on since with 800 watts of power draw I am essentially out of wattage until my new PSU gets here. :sweat_smile:
After 3.2.3 Version my FPS has dropped slightly to an average of 11-15FPS when converting 1080p to 4K in H264 High Nividia with Artemis Denoise/Sharpen on and in MP4 at 40MB/s. I am using a i9-13900KF/4090 with 64GB DDR5 7000MHz water cooled and on a WD 4TB 850X M.2 NVME 7300 R/W Drive with a PSU of 1350 so I have no power supply issues.
Screenshot 2023-04-30 085711
@hugedownload
My 1500watt psu just came in and I should be able to up my game later this week. :smiley:
thanks again for the info! :slight_smile:
This was an interestin read, I’ve been hunting for better performance for a while. Would bumping the CPU up actually make much difference?
Anyway if this helps peoples scaling expectations here’s my testing results:
Note the GPU runs at:
Core - 2745
Memory - 10251
Temp - 55c
Topaz Video AI  v3.3.0
System Information
OS: Windows v11.22
CPU: AMD Ryzen 7 5800X 8-Core Processor               31.925 GB
GPU: NVIDIA GeForce RTX 4090  22.096 GB
Processing Settings
device: 0 vram: 1 instances: 0
Input Resolution: 3840x2160
Benchmark Results
Artemis		1X: 	07.18 fps 	2X: 	02.15 fps 	4X: 	00.34 fps
Proteus		1X: 	05.81 fps 	2X: 	02.13 fps 	4X: 	00.43 fps
Gaia		1X: 	03.13 fps 	2X: 	02.12 fps 	4X: 	00.57 fps
4X Slowmo		Apollo: 	09.48 fps 	APFast: 	12.52 fps 	Chronos: 	06.36 fps 	CHFast: 	09.06 fps
System Information
OS: Windows v11.22
Processing Settings
Benchmark Results
Artemis		1X: 	30.35 fps 	2X: 	10.65 fps 	4X: 	02.50 fps
Proteus		1X: 	24.13 fps 	2X: 	09.56 fps 	4X: 	02.35 fps
Gaia		1X: 	14.79 fps 	2X: 	10.01 fps 	4X: 	02.71 fps
4X Slowmo		Apollo: 	33.00 fps 	APFast: 	47.54 fps 	Chronos: 	30.74 fps 	CHFast: 	27.13 fps
Here’s a video being upscaled from 710x578 to 2160p using:
Gaia - High Quality V5
Type - Progressive
Noise - 1
Grain Amount - 2
Size - 1
Encoder:
Nvidia H265 MAIN (NVIDIA)
AUTO Bitrate & Audio
Note that this actually goes between 8.3 and 8.9fps throughout the tests on this video.
