Unable to install / repair neuroserver - Download points to HTTP instead of HTTPS and does not start
Hi there,
I am trying to re-install / repair after the initial Update to 1.6.1 failed to install
Any ideas ?
Edit:
Trying to download http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz from my browser works just fine.
running the install msi from an elevated promt does not help
The neuroserver json file is odd:
notice that this is NOT httpS but only insecure http
Thank you for sharing the screenshots for this situation. If you launch the installer again and choose Repair, it should complete for you.
I will check with the team further on the URL issue to see what they say.
Thanks, but this error happens both with a fresh install and repair mode. Initial update failed as well.
Are you able to pull the installer log from the system and send in for review?
The app should have generated one and stored it in the following file path: C:\Users\Owner\AppData\Roaming\Topaz Labs LLC\Topaz Video\logs
is this what you are looking for?
[VEAI-Neuroserver] Started VEAI neuroserver download action
Action 13:51:19: Preparing Neuroserver Components. Checking installed neuroserver components
[VEAI-Neuroserver] Installing neuroserver into: F:\Topaz Labs LLC\Topaz Video
[VEAI-Neuroserver] Model root for pyrunner cleanup: F:\ProgramData\Topaz Labs LLC\Topaz Video\models
[VEAI-Neuroserver] Loaded neuroserver runtime version entries from F:\Topaz Labs LLC\Topaz Video\neuroserver\version.json
[VEAI-Neuroserver] Version file entry deps=neuroserver/20260425.1/windows/neuroserver-deps.tar.xz
[VEAI-Neuroserver] Version file entry neuroserver=neuroserver/20260425.1/windows/neuroserver.tar.xz
[VEAI-Neuroserver] Found existing neuroserver version file at F:\Topaz Labs LLC\Topaz Video\neuroserver\version.json
[VEAI-Neuroserver] Installed neuroserver version does not match target; proceeding with download
[VEAI-Neuroserver] HEAD probe: HttpSendRequestA failed for https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (Error: 12029)
[VEAI-Neuroserver] HEAD probe failed for neuroserver-deps.tar.xz; using fallback estimate 3221225472 bytes
[VEAI-Neuroserver] HEAD probe: HttpSendRequestA failed for https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver.tar.xz (Error: 2148074245)
[VEAI-Neuroserver] HEAD probe failed for neuroserver.tar.xz; using fallback estimate 67108864 bytes
[VEAI-Neuroserver] Pre-flight disk check: free=2197842231296 required>=8220835840 (sum=3288334336 x factor=2.5)
[VEAI-Neuroserver] Staging tree armed at F:\Topaz Labs LLC\Topaz Video\neuroserver.new
[VEAI-Neuroserver] Starting download 1 of 2: neuroserver-deps.tar.xz
Action 13:51:19: Downloading Neuroserver Components. Downloading neuroserver-deps.tar.xz (1 of 2)
[VEAI-Neuroserver] Using %TEMP% staging path for neuroserver-deps.tar.xz (cross-drive): C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging\neuroserver-deps.tar.xz
[VEAI-Neuroserver] Active archive path for neuroserver-deps.tar.xz: C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging\neuroserver-deps.tar.xz
[VEAI-Neuroserver] Expected SHA-512 hash for neuroserver-deps.tar.xz (key ‘neuroserver-deps.tar.xz’): cd645df1b56d79949f1b31b29370c774b0ae55008ba2a5ed0633d403949790162ed4ee2d425f6c908ed8f838ae503a01153b687be39a9e0e043bcde7582c324e
[VEAI-Neuroserver] DownloadOneArchive: neuroserver-deps.tar.xz has 3 candidate URLs
[VEAI-Neuroserver] Write probe (pre-download) for neuroserver target directory: C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging
[VEAI-Neuroserver] Neuroserver target dir path=C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging exists=1 isDir=1 readOnly=0 hidden=0 system=0 attrs=0x00000010
[VEAI-Neuroserver] Disk space for C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging: freeAvailable=963240386560 total=1998684401664 totalFree=963240386560
[VEAI-Neuroserver] Write probe (pre-download) succeeded at C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging__topaz_veai_neuroserver_write_probe.tmp (bytesWritten=1)
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 1/3, flags=0x84800000)
[VEAI-Neuroserver][ERROR] Failed to open URL https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 1/3: Error 2148074245
[VEAI-Neuroserver] Waiting 5000 ms before retrying URL open for neuroserver-deps.tar.xz (attempt 2/3)
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 2/3, flags=0x84800000)
[VEAI-Neuroserver][ERROR] Failed to open URL https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 2/3: Error 2148074245
[VEAI-Neuroserver] Waiting 5000 ms before retrying URL open for neuroserver-deps.tar.xz (attempt 3/3)
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 3/3, flags=0x84800000)
[VEAI-Neuroserver][ERROR] Failed to open URL https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 3/3: Error 2148074245
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: https://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 1/3, flags=0x84800000)
[VEAI-Neuroserver][ERROR] Failed to open URL https://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 1/3: Error 2148074245
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: https://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 2/3, flags=0x84800000)
[VEAI-Neuroserver][ERROR] Failed to open URL https://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 2/3: Error 2148074245
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: https://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 3/3, flags=0x84800000)
[VEAI-Neuroserver][ERROR] Failed to open URL https://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 3/3: Error 2148074245
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 1/3, flags=0x84000000)
[VEAI-Neuroserver][ERROR] Failed to open URL http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 1/3: Error 2148074245
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 2/3, flags=0x84000000)
[VEAI-Neuroserver][ERROR] Failed to open URL http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 2/3: Error 2148074245
[VEAI-Neuroserver] Opening URL for neuroserver-deps.tar.xz: http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz (attempt 3/3, flags=0x84000000)
[VEAI-Neuroserver][ERROR] Failed to open URL http://video-models-blue.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz on attempt 3/3: Error 2148074245
[VEAI-Neuroserver][ERROR] All candidate URLs failed on attempt 1/4 for neuroserver-deps.tar.xz
[VEAI-Neuroserver] DownloadOneArchive: backoff 2000 ms before attempt 2/4 for neuroserver-deps.tar.xz
Action 13:51:52: Downloading Neuroserver Components. Retrying download of neuroserver-deps.tar.xz (1 of 2)
[VEAI-Neuroserver] Write probe (pre-retry) for neuroserver target directory: C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging
[VEAI-Neuroserver] Disk space for C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging: freeAvailable=963222716416 total=1998684401664 totalFree=963222716416
[VEAI-Neuroserver] Write probe (pre-retry) succeeded at C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging__topaz_veai_neuroserver_write_probe.tmp (bytesWritten=1)
[VEAI-Neuroserver][ERROR] All candidate URLs failed on attempt 2/4 for neuroserver-deps.tar.xz
[VEAI-Neuroserver] DownloadOneArchive: backoff 8000 ms before attempt 3/4 for neuroserver-deps.tar.xz
Action 13:52:30: Downloading Neuroserver Components. Retrying download of neuroserver-deps.tar.xz (1 of 2)
[VEAI-Neuroserver] Disk space for C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging: freeAvailable=963223924736 total=1998684401664 totalFree=963223924736
[VEAI-Neuroserver][ERROR] All candidate URLs failed on attempt 3/4 for neuroserver-deps.tar.xz
[VEAI-Neuroserver] DownloadOneArchive: backoff 20000 ms before attempt 4/4 for neuroserver-deps.tar.xz
Action 13:53:20: Downloading Neuroserver Components. Retrying download of neuroserver-deps.tar.xz (1 of 2)
[VEAI-Neuroserver] Disk space for C:\Users\draeb\AppData\Local\Temp\TopazVEAINeuroserverStaging: freeAvailable=963223199744 total=1998684401664 totalFree=963223199744
[VEAI-Neuroserver][ERROR] All candidate URLs failed on attempt 4/4 for neuroserver-deps.tar.xz
[VEAI-Neuroserver][ERROR] DownloadOneArchive: all 4 attempts exhausted for neuroserver-deps.tar.xz
[VEAI-Neuroserver][ERROR] Neuroserver install did not complete: Neuroserver component install did not finish: neuroserver-deps.tar.xz. First issue: no candidate URL reachable. Topaz Video will use the built-in backend. To retry, run the Topaz Video installer again and choose Repair. (network-timeout)
[VEAI-Neuroserver] Deferred neuroserver warning until after installer download actions: F:\Topaz Labs LLC\Topaz Video\neuroserver-install-warning.txt
[VEAI-Neuroserver] WriteStatusJson: wrote status=failed reason=network-timeout to F:\Topaz Labs LLC\Topaz Video\neuroserver-install-status.json
[VEAI-Neuroserver] StagingCleanupGuard: removed half-built staging dir F:\Topaz Labs LLC\Topaz Video\neuroserver.new
MSI (s) (E4:90) [13:53:50:875]: Executing op: ActionStart(Name=ShowDeferredNeuroserverWarnings,)
Action 13:53:50: ShowDeferredNeuroserverWarnings.
MSI (s) (E4:90) [13:53:50:878]: Executing op: CustomActionSchedule(Action=ShowDeferredNeuroserverWarnings,ActionType=3073,Source=BinaryData,Target=ShowDeferredNeuroserverWarnings,CustomActionData=F:\Topaz Labs LLC\Topaz Video)
MSI (s) (E4:F4) [13:53:50:883]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSIF68B.tmp, Entrypoint: ShowDeferredNeuroserverWarnings
MSI (s) (E4:90) [13:54:19:533]: Executing op: ActionStart(Name=FixPermissions,)
Action 13:54:19: FixPermissions.
MSI (s) (E4:90) [13:54:19:536]: Executing op: CustomActionSchedule(Action=FixPermissions,ActionType=3073,Source=BinaryData,Target=FixPermissions,CustomActionData=C:\ProgramData\Topaz Labs LLC\Topaz Video\models)
MSI (s) (E4:08) [13:54:19:540]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI667C.tmp, Entrypoint: FixPermissions
Authentication file attributes were correct.
MSI (s) (E4:90) [13:54:19:548]: Executing op: ActionStart(Name=CreateShortcuts,Description=Creating shortcuts,Template=Shortcut: [1])
Action 13:54:19: CreateShortcuts. Creating shortcuts
MSI (s) (E4:90) [13:54:19:552]: Executing op: IconCreate(Icon=mainapp.exe,Data=BinaryData)
CreateShortcuts: Shortcut: mainapp.exe
MSI (s) (E4:90) [13:54:19:555]: Executing op: SetTargetFolder(Folder=23\Topaz Video)
MSI (s) (E4:90) [13:54:19:558]: SHELL32::SHGetFolderPath returned: C:\ProgramData\Microsoft\Windows\Start Menu\Programs
MSI (s) (E4:90) [13:54:19:558]: Executing op: ShortcutCreate(Name=lpoayin1|Topaz Video,FileName=F:\Topaz Labs LLC\Topaz Video\Topaz Video.exe,WorkingDir=F:\Topaz Labs LLC\Topaz Video,Icon=mainapp.exe,IconIndex=0,)
CreateShortcuts: Shortcut: lpoayin1|Topaz Video
MSI (s) (E4:90) [13:54:19:581]: Executing op: SetTargetFolder(Folder=25)
MSI (s) (E4:90) [13:54:19:583]: SHELL32::SHGetFolderPath returned: C:\Users\Public\Desktop
MSI (s) (E4:90) [13:54:19:583]: Executing op: ShortcutCreate(Name=c9eul5w6|Topaz Video,FileName=F:\Topaz Labs LLC\Topaz Video\Topaz Video.exe,WorkingDir=F:\Topaz Labs LLC\Topaz Video,Icon=mainapp.exe,IconIndex=0,)
CreateShortcuts: Shortcut: c9eul5w6|Topaz Video
MSI (s) (E4:90) [13:54:19:595]: Executing op: ActionStart(Name=WriteRegistryValues,Description=Writing system registry values,Template=Key: [1], Name: [2], Value: [3])
Action 13:54:19: WriteRegistryValues. Writing system registry values
MSI (s) (E4:90) [13:54:19:597]: Executing op: ProgressTotal(Total=10,Type=1,ByteEquivalent=13200)
MSI (s) (E4:90) [13:54:19:598]: Executing op: RegOpenKey(Root=-2147483647,Key=Software\Topaz Labs LLC\Topaz Video\NukeIntegration,BinaryType=0,)
MSI (s) (E4:90) [13:54:19:598]: Executing op: RegAddValue(Name=installed,Value=#1,)
WriteRegistryValues: Key: \Software\Topaz Labs LLC\Topaz Video\NukeIntegration, Name: installed, Value: #1
MSI (s) (E4:90) [13:54:19:599]: Executing op: RegOpenKey(Root=-2147483647,Key=Software\Topaz Labs LLC\Topaz Video,BinaryType=1,)
Still unable to install/repair. When will this be fixed? i cannot use the software right now due to this. :frowning:
Same problem here with version 1.6.1 installation. Looks like this problem has been there for a while (since version 1.4) and HTTPS does not help!
Well, I managed to get this working:
  1. You need to download the neuroserver containers from the Topaz servers first: https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver-deps.tar.xz and https://video-models.topazlabs.com/neuroserver/20260601.1/windows/neuroserver.tar.xz
  2. extract both files in a folder called “neuroserver”. You will get some duplicate files warnings but you can ignore those.
  3. install Topaz Video and press OK when you get the “Unable to install neuroserver” message
  4. Don’t start Topaz Video just yet
  5. Move the “neuroserver” folder (and its content) to your “Program Files\Topaz Labs LLC\Topaz Video” folder
  6. Start Topaz Video.
  7. You should see the Starlight enhancements appear in the right column.
Hope this helps for you too!
Thanks, this is working :slight_smile: Awesome job!
Nevertheless, Topaz really needs to fix this!!
It’s been nearly a MONTH without a solution for a product I am paying for.
Please note that I am highly dissappointed.
The team is actively working on this situation, but it is taking longer than anticipated.
Did the steps that Johan shared above work, or has the problem returned?
yes, the steps worked, but it was a pain in the fabolous behind.
The models cannot be downloaded. Installing it again doesnt help. Is there an solution for this problem?
The problem persists in v1.7. Why is it not solved?
Yes, very strange that it is not solved. The issue was also addressed in another thread, but no solutions there either. I tried your earlier solution, but it does not work for me. I can click the starlight app, but when using it it gives an error.
Hi Rik,
did you download the new .tar files that come with the version 1.7?
The old version will no longer work. Look in your installation log files to find the exact web address
Hoyl f*ck this is still not fixed. I am trying to Upgrade to 1.7 and this is still an issue.
@kyle.topazlabs
Should i cancel my payments and simply use the free LTX 2.5 / FlashVRS or SeedVR2 Upscaler that comes with Wan2GP in the future instead? They have a working installer through Pinokio…
Seriously, how hard can it be to fix a http/https issue within your installer?
The team is still working on this situation, as they had a few possible fixes they were trying out to get this resolved for all users who are seeing the issue. The support team has continued to bring this up at every meeting and follow up with the devs every chance we can about a resolution for users, as this is still being seen.
