Turning off crash recovery causes issues when exporting with Starlight
Turning off crash recovery causes the following issues when exporting with Starlight:
  • No audio output
  • The output folder specification is ignored and the file is output to the source folder.
  • The output file name is different from the specified one.
    For example, if you specify “video_startlight_mini.mp4,” the actual output file name will be “video_1_startlight_mini.mp4.”
Turning on crash recovery eliminates these issues, but in that case, the output file is first output to the source folder and then moved to the destination folder. Therefore, I want to turn off crash recovery to reduce processing time and disk usage.
All models except Starlight work without issue even with crash recovery turned off.
This has been shared with the devs for further review and investigation.
Can you confirm what versions of the app you were seeing these issues in for replication steps?
