Hi! Relatively new user of TPAI, but v2.4.1 is unusable.
I use a MB Pro with the M3 Pro chip, 18 GB RAM, running macOS 14.2.1. On v2.3.x I could import, run Autopilot, and export within about a minute, all on battery power. Connecting to a power supply didn’t really change that time. Just to show I’ve tried. I loved 2.3.x, it was a wonderful program.
Now, updated to v2.4.1, it takes over 10 seconds just to update the preview size from 100% to 10%. This is both on power supply, and battery power. Surely this can’t be right?
Clicking on the “Add Enhancement” tab and waiting for the menu to appear is a test of faith. I just tried it, and it took close to 3 minutes to change.
Importing multiple photos at one time is strictly off-limits, as far as the program is concerned.
I’ve restarted my MB Pro just to see if that helped, but no differences.
I don’t really think I’m stressing out the program importing a ~30mb .jpg file. In v2.3.x, I could upload raw .NEF files (Nikon raw format) from my camera and apply all the desired settings, upres to 4x and export without even the slightest frown, TPAI just chugged right along.
As a follow-up, I did reinstall v2.3.2 and suddenly experienced some significant slow down that I can’t begin to explain. Perhaps it’s my MBP, but I kind of doubt that.
Please help.
Hello! thank you for the quick follow-up, that seems to have cleared everything up!
Thank you kindly!
Please get rid of this upgraded interface and give us back the previous version, which was MUCH better in many ways.
