- The bug / behavior you have encountered
Topaz Video AI Linux Beta v5.0.3.0.b - Enabling Frame Interpolation produces blank video output. I am not sure if it is related but I see a model downloading at the beginning of every run. I have included 3 screenshots (2 pics for the editing view is big due to fonts display big and editing view window is not re-sizable in width, on pic with Frame Interpolation disabled) and logs.
Hi Gregory and Topaz team, thank you for this beta and to all the customers posting requests for a Linux version. I recently switch from Windows 11 to Ubuntu 24.04, and I was happy to read a post somewhere that mentioned Topaz Linux beta is available; happy days.
The reason for my bug report is for the " Topaz Video AI Linux Beta v5.0.3.0.b" version, the Frame Interpolation section produces a blank video output when using any Apollo V8 through to Aion AI models. When enabled the video output is a black video/frames at the giving fps. If I disable Frame Interpolation the video out is good (awesome even) thanks to the new Iris, Proteus… models. I want to use Frame Interpolation to fix duplicate frames caused by NTSC PAL standard conversions and the like.
- Your system profile
System Details Report
Report details
- Date generated: 2024-06-02 22:32:43
Hardware Information:
- Hardware Model: ASUSTeK COMPUTER INC. ROG Zephyrus M16 GU603ZW_GU603ZW
- Memory: 32.0 GiB
- Processor: 12th Gen Intel® Core™ i9-12900H × 20
- Graphics: NVIDIA GeForce RTX™ 3070 Ti Laptop GPU
- Graphics 1: NVIDIA GeForce RTX™ 3070 Ti Laptop GPU
- Disk Capacity: 2.0 TB
Software Information:
- Firmware Version: GU603ZW.311
- OS Name: Ubuntu 24.04 LTS
- OS Build: (null)
- OS Type: 64-bit
- GNOME Version: 46
- Windowing System: X11
- Kernel Version: Linux 6.8.0-31-generic
Your log files (Help > Logging > Get Logs for Support)
logsForSupport.zip (16.3 KB) -
Any screenshots as necessary
Frame Interpolation enabled
I have checked the Topaz Video AI Linux Beta v5.0.3.0.b group, and there are no posts about this issue in Topaz Video AI Linux Beta v5.0.3.0.b .
Thanks.
