Topaz Video AI Beta 5.1.4.0.b
Hello everyone,
We have a new beta available for testing.
5.1.4.1.b
Changelog from 5.1.4.0.b
  • Fixed presets not creating
  • Fixed ‘Include Preview & Export Settings’ in preset dialog closing the dialog
Changelog from 5.1.3
  • Stabilization no longer has potential to hang app on swapping between ‘Previews’ and ‘Exports’ tab
  • In-to-out no longer disables the render button if your cursor is near end of timeline
  • Fixed Certain inputs making the timeline UI bugged
  • Fixed certain files not responding to ‘Show in explorer’
  • Fixed default export area not remembering your choice
  • Fixed default profile export setting not remembering
  • Fixed clicking render preview sometimes not putting you in processed area
  • Fixed many scrollable areas not hiding scroll bar when not needed
  • Fixed zoom percentage not updating when using shortcuts
  • Fixed buggy UI for image sequence Video Settings option dialog
  • Fixed broken shortcuts for all player controls in Welcome page
  • Fixed crop snapping to min/max before you finish typing
  • Fixed clicking cancel on preset creation still creating the preset
  • Fixed bug where you could edit video input settings in batch mode
  • Added time elapsed/remaining to previews section
  • Added ‘Close Project’ button under ‘Save project as’
  • Added “Remove Noise” preset to defaults.
Creating presets dialog isn’t working at all now - pressing create button does nothing.
Also, the dialog still disappears if you try and fill out the name before checking ‘include exports settings’.
:thinking:
A mostly-bugfix beta! :+1:
Hey, thanks for the comment. It is fixed in 5.1.4.1.b !
It’s nice to see!
I don’t know if this is by design or a bug, I’m leaning towards the latter, but if you create some previews, then add a 2nd source, and then select the original source, all the previews you made are gone.
We’re working on bringing this back right now. We have shifted focus to stability for the app and users’ workflows for the time being.
@jacob.muchow @tony.topazlabs @luke.roche
Just a minor comment, but since y’all seem to be looking to make the look and feel of all the apps the same with the ‘Wonder UI’, then the preferences menu item needs to be moved to ‘Edit → Preferences’ instead of ‘File → Preferences’ for consistency between apps.
All the other Topaz apps have it under ‘Edit → Preferences’.
This beta continues to have the issue where mutliple previews get merged together and cannot be played individually.
Toggling of “Instant render” with some processed frame kill all thos frame if you tryinh playing it after a cursor move.
Eerything returned to unprocessed.
Processed frames souldn’t be buffered until any new modification ?
Stopping a rendering in “Instant render” (because of estimating it’s too long, mainly because of too high parameters), makes the app. crashing
Instant render, render tons of frames instead on only one
When using split view with parameterss captured, both side are rendered, leaving us with inability to compare :slightly_smiling_face:
Please stop creating new threads in the beta section, all beta feedback should be on the latest beta release thread which is the one I moved all your posts to.
Is today’s 5.1.4 release the equivalent of 5.1.4.1.b, or should we continue testing this beta?
Stick a fork in this beta, it’s done.
