Well, I am pleased to see an export complete after a few failures with recent beta versions.
I will have to look at setting other than auto bitrate in future. A one hour BBC documentary upscaled to 1080P with stereo sound has resulted in a 20.7Gb file. Average bitrate 50.3Mb/s with a maximum bitrate of 77.8Mb/s. I think for 1080P I would like to choose 30Mb/s but the choices on the output menu jump from 24 to 40.
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 58 min 59 s
Bit rate mode : Variable
Bit rate : 50.3 Mb/s
Maximum bit rate : 77.8 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
