it would be cool if we could use a custom command and still see the preview in the GUI and step through frames etc.
This is good stuff.
But I was actually more looking at knowing the order in which the Proteus filters are processed. Because it does make a difference whether you first denoise, then sharpen, or vice versa, for example.
Doing this I def see that doing it such that Enhancement->Motion Deblur->Frame Interpolation can work very well if you make sure to tune the enhancement well to not get artifacts or oversharpen.
It would be nice if
Pressing “export preview command” (or export command) exported the command in a way that was more user friendly, with new lines added so editting the command is easier (I mean add new lines in a way that copy-pasting it into the terminal would still work for the OS the command was exported under)… maybe a new option saying “export ___ command friendly version”
We should move the block elements in the UI on the right, or add duplicates of them even to adjust the order.
This topic was automatically closed after 33 minutes. New replies are no longer allowed.
