Hello!
I have a bit of an issue with the latest Topaz 3.0.X software. I usually work with very high quality/bitrate video files, often in low framerate (Due to their high quality) and I like to use this software to increase their framerate.
Sadly, I’ve come to find out that Apollo; the most effective model for my use case seems to add significant compression/artifacts to the video; or limits the videos bitrate in some way.
Here is an example:
I’m not sure if this is just a result of this model/a “Feature” of it, but I don’t see any similar posts about this.
Please let me know if this is a bug/not intentional, and might be something that would be fixed or worked on in the future; or if this is just how it is.
Steps to re-produce:
1: Import any video of your choice
2: Set the Video Out Framerate higher than the video’s original framerate
3: Select Apollo as the AI model
4: Preview video, zoom in and observe pixels/artifacts
Thank you!
