I’ve been exploring the Impression filter in Topaz Studio 2 and I’m struggling to create an effect that I see in images that have been created with Topaz Impression. I’ve even seen a Topaz Impression demonstration video with it.
What I want to do is see texture in the paint - like ridges so that the lighting direction affects it. How do I do this?
I’ve played with brush type, brush size, paint volume, paint opacity, etc. But it still looks flat - there’s no 3d-element or depth to it. And yet, I see that effect when I look at images others are creating with Topaz Impression.
Is it that this effect was created before Topaz Studio 2? Any assistance, guidance, steer would be greatly appreciated.
Jules, have you played with the default Impression Looks? For example try Monet, then after you “Apply” play with the sliders. Here is a screenshot that might help you find Monet.
Jules, You probably saw an Impression painting with a texture applied. Another way is to do an Impression painting and then duplicate it and apply emboss then blend that layer using vivid light mode.
Thanks for this. That’s quite helpful. And I appreciate the tips.
But I still cannot help but feel that you could do this in Topaz Impression V 1 but can’t in Topaz Studio 2.
You can see what I’m trying to recreate in a YouTube video by Topaz Labs at 33:00 minutes in when the presenter is showing the strokes: Introduction to Topaz Impression - YouTube
If you have paid for the original Impression, you can still download it here then try to produce what you want or see if it is any different. Topaz Labs
Thanks for this. Really appreciate it. I’m just a Topaz Studio 2 client - so that’s probably not an option. I think I’m just going to try using textures to achieve the look I’m after. But thank you again.
