I have just updated to the latest version of Topaz Studio.
I normally open the CR.2 file in Camera Raw and make one or two adjustments
and then open up Studio to use AI Clear but when i try to open the image in Photoshop
it says Could not complete the Topaz Studio command because the file was not found.
I have never experienced this before updating to the latest version of studio
Make sure that the image is opened in Camera RAW first and you are not cropping the image as that is what it looks like you are doing. There is no layer showing on the right hand panel.
You need to open the image, select a layer and then Filter-> Topaz Labs-> Topaz Sharpen AI.
That is what i am doing
Firstly i open in Camera Raw and make a couple of adjustments and then open the image in PS
i then navigate to Filter-topaz labs-Studio-which is at the bottom of my filters list and when i try to
open it i get the message on the screen
I am trying to use AI Clear in studio as i have the pro version which is not standalone.
I downloaded the trial of AI sharpen yesterday but not really used that. At the moment want to use
the AI clear.
I have included another screenshot
Hi,
Please accept my apologies as i have just realised what i have done wrong.
I deselected the crop and all working fine now
A very senior moment on my behalf.
