Topaz Studio | Transition Questions
Sorry for all the questions, but still a bit confused. This page here is saying it would be the same price as I pay now Log in to check your Topaz Studio launch perks.
which makes it sound like if I only had 2 apps, I would get a better price than I am now with 3 apps?
Yes! I’d download the new ones first just to make sure everything is working properly on your system.
I am a long-time user with all three licenses active until mid-December 2025, and from the dedicated web page, I have already been “selected” for the activation of the new studio apps
 but I have not yet activated any automatic renewal for any of the three licenses. Do I have to activate at least two auto renewal licenses in order to take advantage of the initial studio app promotion?
Yes, it says unlimited cloud IMAGE rendering, i.e. not video.
I don’t understand why Gigapixel and Photo AI are separate, they might as well just merge the features together as one photo app as they are practically the same thing.
It is a different application, yes. But many shared features on launch of course.
We’ll be able to detect your existing model repository so you won’t need to download all the models in most cases.
Unlimited cloud rendering is Photos ONLY
 Plus, you get 300 Video Credits monthly ($30 monthly value)
Ahh that makes sense, it didn’t mention that within the release notes. Thank you
Thank you.
That’s for those on the Studio plan. Depends on the model used! Should be somewhere in the range of 10-20minutes of Starlight Mini depending on resolution from what I see. You can check in the app now actually.
Images only yeah. We tried so hard to get unlimited video for ya but GPUs are just so darn expensive and video files are so large and costly.
I would recommend activating all auto-renewals for the best experience here and automatic transition. Otherwise you’ll get an email and will have to do a manual checkout to create a new Studio subscription
We did that originally and people kept wanting to use Gigapixel :slight_smile: so we brought it back. And it is now much better at colorspaces, large images, has generative models, and more. Photo has broader applications and also handles RAW images.
If I activate auto-renewal for a product that doesn’t currently have it, doesn’t that mean it will automatically charge my credit card on-file for a 1-year subscription I don’t want?
Do the unused (300) Cloud Credits roll over or do they need to be used within the current said month?
Hi Dakota, Just to verify
 is everyone going to receive an email to install the new program or are you going to post where to go for the download on here?
Depends on whether it is active or not. If not, you’ll of course have to purchase an upgrade. If already active, it is just checking a box which turns this into a subscription (no current charge).
They will expire at the end of the month
