I am not sure where the appropriate place for a Studio question is so, if this is the wrong place, perhaps someone could let me know where it should be and I will move it (or the moderator could move it).
I have just downloaded the new Topaz Studio app and have been playing with it to see how it works. For the most part it is self-explanatory but I have run into a question that I can not answer.
I wanted to copy a mask for use in further adjustments. That is, I want to mask out one section of the image, apply adjustments to that masked area and, when done, apply the same mask, invert it and apply adjustments to the other part of the image.I know I can invert the mask but I want to finish one set of adjustment, press Done, then use the same mask, inverted, on the same image for a second set of adjustments. The problem is that I can find no way to copy the mask.
I assume this means that there is another way to do what I want as copying masks would seem to be pretty basic functionality and if I can not do it, then there must be another way to do what I want. Can someone help me?
Thanks.
