Loving the new Topaz Studio 2, but just wondered if you could modify the Straighten Tool so we can select 2 points on a line in the photo which should be horizontal,(or vertical) and TS2 will automatically straighten the image to align correctly.
Good luck…
Whilst on the subject of straighten…
If you click on the straighten slider button to use that to rotate the image, the crop grid changes from the normal 1/3rd’s lines to 1/6th’s, which is quite useful.
We all know though that the slider is way too sensitive when used with a mouse, and it is far easier to click into the value box and use the up/down keys to rotate the image.
Does anyone know how to change the grid to 1/6th’s when using the value box for rotation ?
