Hello, I am trying to sharpen the attached image. While sharpening the app just quits. No crash notification or anything other than the app just disappears.
Processor 4.2 GHz Quad-Core Intel
Core i7
Graphics Radeon Pro 580 8 GB
Memory 64 GB 2400 MHz DDR4
Ventura 13.2.1
Topaz Sharpen Al Version 4.1.0
2022 Release
2009-2022 Topaz Labs, All rights reserved
CPU Architecture: x86_64
You will need to raise a support request at the main website… It is on the support page in the form of a conversation icon, click on that and follow instructions.
The error log shows a crash with the GPU.
Note that the system requirements say is 10.14 and over is supported but should run on 10.13 so you shouldn’t have a problem with the OS.
