I’ve just exported a black and white image from lightroom to Topaz Sharpen AI and if I select out of focus very blurry it adds a blue hue to parts of the image, as you can see on the left hand image (edit it doesn’t show very well uploaded on here), it doesn’t do this with other presets such as out of focus normal and too soft etc.
This is because, Sharpen AI’s Machine Learning was never trained with either Black & White or Scanned images only Colour Digital Images
Having said that, I myself and others have had miraculous results using Topaz Sharpen AI on both Scanned and Monochrome images unfortunately as I said before as the application wasn’t trained on these types of pictures then sometimes you will experience a slight hue change which can be easily rectified within Photoshop or any image editor of your choice
