Topaz Photo v1.6.0 - Recover Faces 3, Sharpen - Noise-Aware, & NeuroServer Model Speed Ups
Yes it does.
“Claude, improve Topaz Wonder model, make no mistakes”
:grin:
But i think it wasn’t right.
My image did exeed the internal limit for everything - ending up at 58000px - even for a downsizing to 32000px there is no room for it.
Now i did target 31000px and downsize before upscale, did work then.
AI’s will give wrong answers quite confidently.
AI “Your image is only 16000px it should work”
Me “No, it’s 58000px”
AI “You’re absolutely right!”
:rofl:
A post was split to a new topic: Ability to force Recover Faces v3 and Upscale Recover v3 in Preferences
Is it safe to end task this if I am finished photo editing for a day, it just sits their hogging 8gb of Memory otherwise:
Definitely. It’s supposed to shut itself down automatically when you close Photo.
Whilst I am waiting for support to answer, anyone else had a problem logging into Topaz Photo 1.6.0? I had to uninstall and re-install as it was having problems with model error, now after re-installing and trying to login, I get the error in the screenshot. The e-mail is 100% correct.
I’m having the same login problem as you.
Log-in is not possible from the previously installed version 1.4.0, so I downloaded the 1.6.0 installation file and updated it
After the update, the login issue remains the same.
Interestingly, only Photo is experiencing this problem, and Video is logged in without any problems.
As far as I’ve searched in forum, I’ve found a few cases of login issues in the past version, but I don’t see anything about this version 1.6.0.
It’s frustrating that I can’t do anything because I can’t log in, even though I need to work on it right away.
+Additional
I tried to log in again about 15 minutes after I wrote the reply, and I logged in normally without any problems.
Maybe, there was a temporary problem with the Topaz server.
@DTiGeR we have fixed the login issue this morning. Please give a try again
Thankyou for the Quick fix
Issues with tile rendering. Some tiles are sharp, while others are very blurry.
hello. when is v1.6.1 releasing?
Welcome to the forum unpolls1 :slightly_smiling_face:
We will be releasing v1.6.1 later this week. This will be a patch release focused on bug fixes and NeuroServer optimizations.
Once it is available, you’ll see the update notification in the top-right corner of the app.
Stay tuned!
thanks
Before release, could you please correct the high-fidelity v3 model? The rendering has a slightly greenish tint. This is even more noticeable in black tones. It’s also visible in blue tones, which become a bit cyan.
I did it in Gigapixel, but since the same model is present in Topaz Photo, the problem is identical.
Thanks. The development team is aware of this issue and your contact information was added on the development team ticket for this to contact when it is addressed.
Nice.
