When saving a Canon Raw file (CR3) back to Canon Photos, application hangs. The wheel will spin for a very long time (half hour) and never return to the Apple Photos app. It works fine with JPG just not the Canon camera raw.
Upsize Rescale applied to original photo, and not applied to cropped photo, causing exported photo resolution is much more smaller than desired resolution. Version 2.3.2 and before are correctly applied, please make it like version 2.3.2
Please, please, please.
I’m really hoping that remove/reconstruction part is usable again, like in TPAI 2.3.2. ![]()
Time to test! ![]()
First thing we have to do is to zoom out image to fit than apply any filter so the open panel does not cover the image. why it is not possible to open panel on empty space
Having the same issue! Prior versions of PhotoAI returned processed images to LR Classic as DNG. I don’t like the change to TIFF as some LRC editing options are not supported as they are with a DNG file. Option to export as DNG seems to only work if PhotoAI is used as stand alone now…please go back to DNG or at least give option for plugins…
Thanks as well for saving the frustration of installing another version with the memory leak bug.
Hard to imagine how a critical bug such as a memory leak could not have the very highest priority. Unfortunately it does not instill confidence in the development team leadership and future of the product.
Hey michael - which denoise models and strengths are you using in Denoise AI vs Photo AI?
Thanks first - I’m also using a macbook and I feel the same way. But we’re still continuing to work on optimizations and fixes here to make it even faster. There’s a few areas we’d like to improve in particular. Cheers.
Good idea Michael. Also noting your Nikon Z8 issue in your other comment. We’re keeping a log of camera issues to tackle. Cheers.
Thanks sam - and yeah we’re aware of the memory leak issue, will be tracking down the fix. All the best.
Thanks andy, this is helpful feedback.
Thanks plugs - helpful feedback as always. Cheers
Hey javier - good to know this is on the Z8 as well, I saw michael’s comment about his similar problem. Thanks for letting us know.
In Denoise AI mostly Low Light and Raw
In TPAI - I tried all models, but those large (and specifically) color blobs don’t disappear
Interesting. Please DM me a message with the original photo if you don’t mind sharing, I’d like to run some tests on my end. Cheers.
Fortunately, many of us do have confidence in the development team, the leadership and the future of the product!
Why does this still exist? All my autopilot and related settings are OFF but this still slow down my work when I quickly need to upscale something.
My biggest problem beyond speed is probably something you can’t fix. RAM. Before Topaz 16 GB was plenty for anything I needed to do. But to fix that means spending 2000 to 3500 bucks when one is on a Mac.
