“Recover faces” is not recognizing all of the faces or no faces at all at low quality photos or low quality and low light photos (like negative scans).
It recognizes much lower quality and very blurred faces on photos from digital cameras (including smartphones), but it has problem with recognizing faces on noisy low quality scans from analog cameras (if some faces are recognized - it makes a great job!).
PLEASE make MANUAL ADDING of FACES available.
You can select face(s) ONLY if there are any recognized !!! If not I got the message:
“Faces recovery disabled because no faces were detected in the image” !!!
That is why I suggest to add possibility to make “MANUAL ADDING of FACES” available (I didn’t write select!)
And I underline: I had faces much worse quality, that were recognized and recover (with great quality), so when I can see face that is better quality than already recovered I would like to have it recovered too, but I can’t as the Photo AI doesn’t recognize that particular face
I experienced the same problem, but was able to improve it by up increasing Face Recovery Strength above the default of 80. I accessed this through Edit/Preferences/ Auto[pilot/ Face Recovery. I still like the earlier selection technique involving brushing to select the desired portion of the images.
I agree with the person who suggested adding a Manual method to select face recovery. As it is now face recovery does not do or allow anything to let the user select a face that Photo AI does not recognize. making changes to it in Preferences does NOTHING to fix this problem.
