The before and after window on Tobaz V2 are not aligned, Are issue when trying before and after slider,
@william.fryman This is the first report of this that I’ve seen. Can you send a screenshot?
I suspect there might be a pixel shift. Are you using RAW files?
Yes raw files direct load to Topaz
Canon 5D mark iv
Mike Fryman
Pixel shifts for some RAW files are a known bug that our developers are currently investigating. Thanks for the info and for your patience while we fix this for you.
I observed that if I use this on photo that been through LR enhance, this problem will occur
