I really need Topaz JPEG to RAW, but of course it’s not available since 2022 I think.
Do you have any idea how I could get it now?
Thanks in advance ![]()
Hi. If you have access to either Topaz Gigapixel or Photo AI, the JPEG to RAW functionality is built into both of these products.
Basically an 8-bit JPEG image is automatically converted to a full high quality 16-bit image the same as you got with the now discontinued JPEG to RAW app
Hope this helps
Thanks for your answer ![]()
But in Photo AI or Gigapixel AI do I have the option to set the level of JPEG artifacts reduction with a slider? Or is it fully automatic?
Hi. Although JPEG artifacts for the most part are taken care of automatically you always have the option of fine turning with the noise sliders and the model you choose
