Topaz Gigapixel AI Update 8.3 The program closes and does not work
Finally, the issue with the new 8.3.3 update has been resolved.
The matter is now closed.
Best regards.
:star_struck:
Nope, still no go here. Upgraded from 8.2.2. to 8.3.3. App still doesn’t appear when launching… never gets into the UI. Tried running as admin, still nothing.
Just did upgrade to 8.3.3 and software still crashes when trying to load an image. Any image, any format. This is starting to get REAL OLD !!!
Thanks for this. This time I made sure to check the forums before upgrading.
Will not install the new update until there’s unanimous feedback that it’s solved.
In my case, the issue was resolved, and it works correctly.
You might try uninstalling the application and installing version 8.2.2, which was working fine.
Then, update it directly from that version to 8.3.3.
It might help!
Good luck!
PD. You can send an email to support explaining your specific issue at help@topazlabs.com.
No luck… that’s exactly what we did already.
Still won’t load the UI.
