Topaz Detail 3 - fewer presets
I notice that in Detail 3 Presets under Creative Detail section I only have 4 Presets - there were many more in Detail 2 - where have they gone ?
:frowning:
Geoff
There are 10 ā€¦ can you please post what OS your PC uses and then we can give a solution.
Don,
I am using Windows 10 64bit.
Cheers,
Geoff
Hi,
Go to the directory ā€œC:\Program Files (x86)\Topaz Labs\Topaz Detail 3ā€ and delete the file named ā€œTopazPresetsDBā€ and then restart Detail and the presets should be there.
Check first that there are 10 preset file names in the directory ā€œC:\Program Files (x86)\Topaz Labs\Topaz Detail 3\Presets\Creative Detail Collectionā€ if they arenā€™t there it may mean they have been deleted so you will need to download and reinstall from the download site at (do not download from your account page):
https://www.topazlabs.com/downloads
Thank you - all fixed :slight_smile:
Don, why is there a problem downloading from oneā€™s account page please?
Moderators arenā€™t really equipped to answer questions about our site, those are more for staff to answer. If you cannot download from your account page, try the downloads page:
