Topaz AI is miscalculating the PAR to 0.89:1, but it should be closer to 0.91:1 or 10/11
I am converting the file to 1080p
Pixel Type: Original Pixel Type
Crop Settings: Letterbox/Pillarbox
And the converted file is narrower than the original
Sorry, i read previous post, and I just entered a custom resolution and I locked the height to 1080, so width was calculated to 1620, and i used original pixel type and the aspect ratio is now correct.
I just wish their was a setting that did this automatically, so i dont have to consider when I upconvert different low oddball resolutions
you should had selected Square Pixel type and the 1080p selection would do the rest to sort out your aspect ration.
