I don’t know what on earth you did with this latest update, but it’s HORRIBLE!!! It’s difficult to navigate, and the results are indescribably bad.
I played around with varying degrees of strength and it either came back with no change at all, or something unrecongnizable.
Please fix this ASAP
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
