I don’t understand why the other TopazLab products have a standard brush for masks, while PhotoAi has this smart, slow and impractical brush. Would it be possible to have a toggle to use smart brushes or the old brush like on SharpenAi for example?
v1.2.4
- Added basic masking brush
– Switch between AI brush and the basic brush while in refine mode with the “b” hotkey, or use the toggle on the right panel
Thank you, I read the notes from version 1.2.4 very distractedly, I read the brush but hadn’t seen the toggle to go back to the “normal” brush. However, the Ai brush, intelligent, has nothing. For that they will have to take a cue from the ‘super select ai’ of On1: the one that is smart !!
