Suggestions for improvements for Video AI
  1. Add deflicker
  2. Add pause process ability during the export
  3. Αdd color , contrast and saturation in process
  4. Reappearance STOP PROCECING BUTTON in previews
A PROC AMP with Adjustments for BLACKS, SHADOWS, WHITES, HIGHLIGHTS, CONTRAST, GAMMA, EXPOSURE, TINT, SATURATION would be great. I guess it should be a Pre amp as using it Post may introduce some noise.
In terms of the anti flicker there should also be a setting for NON-AI deinterlace settings in the Video section right under the frame rate drop down.
I would use the settings like VLC has with many Blend Modes etc. as these should open source plug-ins or settings for codecs and encoders.
An interlace deflicker checkbox with a slider like in Premiere would be great.
And a Swap Dominate Field checkbox would be a great idea to put in the Video panel.
As it stands anytime I attempt to use TOPAZ to de-interlace these lined boxes that look like glitches randomly flash all over highlights which makes TOPAZ unusable for that function when it comes to AI.
I hope they can fix this because a working AI De-Interlace ONLY Pre-module would be great for fixing footage from others and for getting a higher quality out of older footage before cleaning and resizing.
But for now a simple NON-AI Deinterlace drop down would be nice to have.
J3D
PS The Auto Playback Preview after rendering doesn’t work.
