How can we apply a style on top of another?
Can you provide a little more information please.? Such as what product are you talking about and what are you trying to do?
It sounds like you might be asking about adding one preset, then adding another, and possibly more, that would be applied one right after the other, rather than replacing the previous preset.
To do this, you’ll want to:
- Select a preset for your image
- Select the Apply button
- Select the next preset for your image
- Repeat as needed
That’s it!
Thank you Joe!
