Thanks for the free upgrade to Studio 2.
I found that when I go back to AI Clear a second time the “Remove Noise” button switch to “Auto” although it was set to “Low” in the first place. This happens when I used some others filters on top and go back to AI Clear. Not a big deal right now, but that should be fixed because the Noise reduction changes the result.
best regards, Volker
