I have installed Topaz Studio 2, v. 2.3.1 several times. It shows up as a plug-in Photoshop, but no version of Studio 2 has ever shown up as a plug-in in the Edit In menu of LR Classic… Topaz Studio 2 (Beta) shows up but not the release version. What do I need to do to get into LR Classic? Thanks
Try this article, works well in LR older versions also:
Don,
Thanks. That’s what I have been doing. However, when I click on Edit In, there is an alphabetical menu of all of my LR plug-ins. What is there is what you see in the screen shot. All of my Topaz plug-ins, with the exception of Topaz Studio 2 are listed there.
Jack
Screen Shot 2020-06-30 at 5.04.44 PM.pngIt seems like you need to cleanup your external editors by deleting and then readding the correct ones. And also cleaning up the installed applications.
I would only have the latest installed as they no longer need to run as a standalone to change from beta to production.
