Importing raw image from LR or PS loads with the correct color in Studio 2.2. When importing the same image directly from Finder on Mac, it loads with incorrect color. The image is too dark.
What is happening//
What is happening//
There are many other posts here that explain that Topaz are working on improving the RAW processing to an acceptable level.
Continue to use your existing RAW processors in the meantime as the RAW image is exported to Studio.
