Stuck between Downloading Model, Loading Model
rendering is stuck between downloading model aion and loading model. goes in-between itself while stuck on estimating. ive reinstalled and repaired with the same issue appearing.
nvidia 5070/ ryzen 5700x / 36gb ddr4 / 2tb ssd nvme
my laptop runs with no issue with no need to download anything
Can you send a screenshot and the logs from the app to the support team for investigation?
help@topazlabs.com
logsForSupport.zip (278.8 KB)
Open the Preferences Panel and change the following settings as the logs you shared show some memory errors occurring.
File>Preferences>Processing
  1. Ensure that your GPU is selected for the AI Processor
  2. Set the max memory to 80%
  3. Set max processes to 1
  4. Save the settings and close the panel.
  5. Re-run your clip through the process that you were trying.
